90 oil filter housing have oil feed port?
canonize-ryda
264
Apr 8, 2011
Gillette, Wyoming
After a little searching all the threads are a little unclear. Does the 90 oil filter housing have a port for the oil feed line? I'm looking at a oil feed kit and it feeds from the housing and provides a 90 degree fitting to housing and -4 an. It doesnt tell me about what size the housing is it just says it fits it. Will this work?
Thanks
It was a bit of a facetious remark as there really shouldn't have been a reason for you to ask the question "port #3 or port #1??" after reading the links provided for you (which I trust you did). :)
I wouldn't have said, "If you want filtered oil..." if that isn't what I meant. Anyone in their right mind would choose filtered oil over unfiltered oil to send anywhere in their engine, including the turbo. But as you read in the first link, some people mean well and still make the wrong selection due to unsubstantiated information. ;)
Cool, thanks for the post. I will run a separate braided oil line to my turbo and plumb a gauge into the port on the oil filter housing.
Cheers
Ross
That diagram is correct and the way you should run it. I have it that way on my 90.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
