mach4g63t
- 402
- 0
- May 28, 2007
St. Louis,
Missouri
Hey, I'm looking into buying a really cheap 1st Gen GSX 5-speed off e-Bay right now. The listing says that the timing went bad and a couple of the Intake Valves were bent. I was wondering, from a novice standpoint with little experience aside from bolt-ons, how hard is it to replace the valves your self? Does it require any special tools? Also, I remember when I bought my old TSi AWD the timing belt snapped, blew the head, and valves were bent as a result. Are there any other possibilities of damage that could've been done to the motor subsequently?
Also, while I got the thread open, aside from the basic maintenance that would/should be done while the motor is apart- what are the benefits of putting 1mm large valves are the car? Would it be ideal to do it to a motor that's probably going to be relatively stock for a 'little while'? Are there any other things I should consider before buying this car?
Thanks for any info and help
