1Ga-1Gb headlight conversion. Its not that hard
Posted by GSXftw, Feb 9, 2012
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Race Components Inc
  1. GSXftw
    GSXftw Proven Member
    DSM Profiles:
    4
    Dec 16, 2009
    151
    73
    Medford, Oregon
    Let me start by saying If you have all the needed parts for this it isnt THAT big of a deal as long as youre comfortable working on your car.... I had a complete 94 gs parts car, stripped it of everything I could think of I would need, and had everything changed over in 9 hours. I drove into the shop with pop ups, and drove home with stationaries. I do see a lot of threads where people are ASKING about this conversion... but not a lot of info and a walkthrough.... I read everything from "it cant be done the front clips are different", to "its all bolt on" So let me get some info from my experience out there with some pics.
    First off, what I got off the 94 parts car-
    The majors like the hood, Fenders, and Headlights are obvious, but the less obvious that you'll be glad you got too are- the wiring harnesses off the headlights, the bumper, and then the front frame work that support it all is optional. If you want it to look factory then yes, but if youre like me and work smart not hard dont worry about it.
    Now I didnt have a good front bumper on my 1Gb parts car, so I left my 1Ga bumper on for the time being. You'll see the difference but it isnt huge, and after I make a center piece to fill in the space between the headlights, you wouldnt know the difference. The 1Gb bumper works as the filler, and 1Ga has a plastic piece that is smaller. Also I DID NOT get the front frame work. I had to quickly strip my parts car and let it go, and plus I am not scared of metal work and knew I could cut and fab if I needed to.
    So what I started with
    [​IMG]
    Another reason for this was my fender was dented from an idiot deer
    Off to the shop
    [​IMG]
    So first things first....strip it on down
    [​IMG]
    Some notes- You need to remove the washer wiper resivor, loosen your PS resivor, loosen the AC line hold downs on the left side too (no you dont need to loosen your connections or lose your system charge just get it outta the way)
    Now the big thing that seems to be missing when you search for this conversion.... WHATS DIFFERENT UNDERNEATH- Well here ya go
    [​IMG]
    You'll find out what you need to do real quick.... make room for the new headlights to sink in deep enough. Heres what it needs to look like
    [​IMG]
    [​IMG]
    You need to solder in the new harnesses. As far as colors go, on your 1Gb harnesses they were thinking and made the black the ground, on 1Ga they did not, it was one of the reds :ohdamn: Get out your test light and find which one, and dont pop fuses just use your head and connect your test light to positive, and when it lights up from one of the wires thats your ground wire.
    Heres what youll have cut out when youre done
    [​IMG]
    ....and the moment I was waiting for....
    [​IMG]
    Final thoughts... This definitely saved some weight... the hood on the 1Ga was actually heavier despite the smaller size, the headlight buckets were surprisingly heavy in addition to that, plus youre ditching the pop up motors. Not only do you drop weight but you get some MUCH needed engine bay room! Much less clutter.
    As far as looks this will be debated back and forth forever, its all opinion, I myself LOVE the new look, and my 2nd gen Supra has pop ups still :D
    but opinion aside some facts that make this worth while are, weight, room (less is more), aerodynamics, and better lighting with more aftermarket availability for bulbs. I had Halogen headlights in my pop ups and they were still horrible, the low beams were dull, and high beams were most peoples low beams. The 1Gb lights the road up MUCH better, and theyre still stock! So dont be scurred if youre thinking about this, youll be happy you did! Also I have all this stuff that came off my car for sale, if you want it PM me.
    #1
  2. CrawlinZX14
    CrawlinZX14 Proven Member
    Sep 7, 2011
    452
    Carpentersville, Illinois
    I love the write up and concept, but the picture quality is poor at best, and honestly you probably need more photos. I plan to retrofit mine in the near future as well, but im just dumping the frog eyes and making a pod in their place with projector pods and HID's and keeping the front end "looking" stock 1ga style. The lids for the pop ups will simply become decoration access hatches for adjusting the beams. But that is a whole other write up when I delve into that project. +1 on the swap. I think more pix of material removed would have helped and from better angles. I could not tell what you removed at all, and where it all came from. Pictures of the markings would have helped pre cut, during cut and after cut. So there was before and after. And a clearer picture non camera phone would have been better. Nice swap tho.
    #2
  3. GSXftw
    DSM Profiles:
    4
    Dec 16, 2009
    151
    73
    Medford, Oregon
    I hope this helps
    [​IMG]
    thank you for the kudos and sorry about the quality
    #3
  4. CrawlinZX14
    Sep 7, 2011
    452
    It helps a bit. But again, I think different angles would have benefitted more in a writeup perspective. Looks clean tho as a finished product, and if you would not have said it was a 1ga before, I probably would have never known it was converted just by looking at the front. Well done. I hope my setup I am working on making comes out as cleanly.
    #4
  5. GSXftw
    DSM Profiles:
    4
    Dec 16, 2009
    151
    73
    Medford, Oregon
    Just wanted to update that I went from this
    [​IMG]
    To this
    [​IMG]
    Oh yeah...
    #5
  6. DSM1G90
    DSM1G90 Supporting Member
    DSM Profiles:
    Apr 6, 2008
    4,830
    53
    Nampa, Idaho
    Now, why would one want to rid a rare and classic look of popups to a plain looking front end?
    #6
  7. GSXftw
    DSM Profiles:
    4
    Dec 16, 2009
    151
    73
    Medford, Oregon
    I have just always liked the 1Gb... personal taste I guess. I will definitely say one thing though... The drivers side engine bay went from an absolute bear to work in, to managable =) It cleared up a bit of much needed space
    #7
  8. 92gsxecl1pse
    92gsxecl1pse Proven Member
    DSM Profiles:
    May 9, 2009
    79
    Columbus, Ohio
    I was just wondering ive seen people swap 1gA to 1gB But is it possiable to swap 1gB to a 1gA I truly cant stand the 1gB...even tho ive had 2. I love the flip ups and was wondering is it possiable to swap to the flip ups from my 1gB. Thanks
    #8
  9. Mr PopUps
    Mr PopUps Proven Member
    Jul 10, 2009
    393
    Ft. Mitchell, Kentucky
    Yes. But i dont think the wiring will be there for the headlight housing motors :(
    #9
  10. DSM1G90
    DSM Profiles:
    Apr 6, 2008
    4,830
    53
    Nampa, Idaho
    You'd have to get a 1Ga harness, headlight motors and the switch that hooks up in the gauge frame to manually pop up the "eyes"
    #10
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
