Get 200 A-spec points.
NegativeCamber
30
Dec 8, 2004
New Castle, Delaware
I was messing around last might trying to find some things out about the a-spec points system, and this is what I've found out so far about it, from what I can see anyway:
1. A-spec is a direct value for how hard the cpu thinks the race is for you to win, ranging from 1-200, 200 being impossible. That is why there is the "Best A-spec points" display in the menu for each race. A-spec points aren't really worth anything other than bragging rights. I still like it though since it gives another challenge in the game. Some people say it makes the opponent driver AI better, but I haven't noticed that.
2. The point value is based on the overall average of how good the other 5 cars are. I found this out by consistantly getting beat by the 500+HP Buick Special with only 10 A-spec points available in the classic car cup. This was because the other 5 cars were so weak. So the closer the field the better you chances of winning and getting higher A-spec points. Some races are closer than others as I'm sure will notice.
3. *Now here's my real discovery*. The point system is based on power-to-weight and nothing else. All suspension mods and drivetrain mods didn't change the A-spec points and neither does nitrous. That being said you can fully tune your cars suspension and drivetrain, and beat the other cars while getting alot of A-spec points. I was getting 200 A-spec points easily by using a '95 Skyline N1 with 341HP plus nitrous, suspension in the Turbo Car Cup. Also, if you winning races too easily and want more points you can add ballast weight to in the settings menu. Just something to think about if you're trying to get your A-spec points up. :thumb:
Also if you mod the dodge hemi truck you can get alot of a-spec points a race.
Here is the quote
GTPlanet.net said:
Quick - Anyone who wants to rack up a lot of A-Spec points trick out a Dodge Ram and enter it in every race you can. For whatever reason the A-Spec formula does not give a 568HP (can go higher) ram a snowball's chance in any race I've done with it so far. Even in a beginner hall sport truck race that I got 18 points for with a bone-stock lightning, the Ram was awarded 175 points. In the begginer league 4WD races, I could trounce an Audi RS6 by 12 seconds in a 2 lap race and BAM 200 points.
A-Spec points were a good idea, but they may have been poorly executed.
ps - Here are the the specs of the ram as I ran it:
568HP
Stage 2 NA Tune
Racing Rom
Stage 2? Exhaust
Oil Change
VCD set to 10/90 F/R
On stock S2 tires (ya right, how many Rams are wearing AO48s in the showroom right now?)
Stage 2 weight reduction
Stock Suspension
Racing Brakes
A set of sweet black w/ yellow lettering wheels from OZ Racing
Yeah I've noticed it gives some cars a better chance than others. I think the truck one might be because it weighs so much. Also, I think that tires might have an effect on the points. I'm gonna try this out tonight.
Another choice is to go to Mission Races, select the mission Pass At Tsukuba and do that. You don't even have to take the turn, just jump the gras and your at the finish line. Easy 250 A-Spec points.
