Is this the 90* oil fitting i need?
jwahl16
427
3
Oct 26, 2009
Havertown, Pennsylvania
DON'T use aluminum AN fittings on your turbo's oil supply line unless you absolutely must. If anything were to fly up and hit that fitting off the road, it would shear right off and you'll pump your oil pan dry in about 38 seconds.
Aluminum fittings can also crack easily from vibration and go unnoticed. The steel fittings are much more durable against stripped threads and general abuse.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
