Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Turbo System Tech
Turbo System Tech 4G63 turbos, Intercooling, Boost Control, Wastegates, etc.
Reply
LinkBack Thread Tools
Old 11-02-2009, 08:25 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
DSM_ThuNDeR's Avatar
Tech Posts: 133
Photos: 14
Classifieds Rating: 3
Reputation: DSM_ThuNDeR is an unknown
Question Punishment Racing Tial 38mm MVS Wastegate Install
I bought a pakage deal a couple of weeks ago from punishment racing. It seems that the MV-S vband 38mm wastegate is new for 2009, so there isn't really accurate proper installation diagrams/pics that I have found (ONLY FOR F38).
Talon/Eclipse Tial MVS 38mm Wastegate / Recirculated o2 Housing Package
I have took out the flapper, and ported the hell out of the whole. I installed it just this weekend, but decided to go WOT just today. According to P. Racing, this wastegate comes with a 1.0 bar (14.50 PSI) But when I got on it, my boost gauge reads 20-21PSI! This wastegate has three ports on the bottom, one on the side of the top, and ONE ON TOP. Where exactly can I tap my boost source to this wastegate with my MBC? If anyone has purchased it and has installed it, please post up some pics and a little info too. The Post that Punishment Racing has here promoting this wastegate isn't really useful on the count that they said they were going to post some installed pix of the gate, but NOTHING
I am really confused. I hooked up the gate T'd off at the BOV running straight(No MBC) to one of the three bottom ports, top side port is blocked off, and top is left to vent to the atmosphere.
Well thanks in advanced.
View photos of this member's car
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 11-04-2009, 01:08 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Tech Posts: 97
Photos: 15
Classifieds Rating: 1
Reputation: 1FAST2G is an unknown
You need to plug 2 of the bottom holes and run the line to the last one. Leave the top one vented.
How do you have it hooked up now.
Old 11-15-2009, 03:58 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Tech Posts: 133
Photos: 14
Engine Bay
Wastegate
BLANK PIC of the wastegate for you guys to draw and show me how to hook it up:
http://i79.photobucket.com/albums/j1...00276CLEAN.jpg
I will be really happy if I got this dam thing to work. Another thing where exactly can I put my MBC?
I forgot to mention, I do have another vaccum nipple for the wastegate that came with the pakage but did not install that one.
Old 11-16-2009, 08:34 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
Tech Posts: 37
Photos: 21
Reputation: twistedcm2 is an unknown
Can you share where you bought those plugs for the rest of the holes you blocked off?
I ran mine without them plugged and had a hard time controlling my boost but I'm wondering if this was the reason why.
____________________________
Richard
Broke college student bc of car
Old 11-16-2009, 09:29 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Moderator
99gst_racer's Avatar
Tech Posts: 4,738
Photos: 58
Classifieds Rating: 31
The Tial MSV comes with those plugs. All lower ports (except for the one you're using) need to be plugged, otherwise the wastegate will not properly function.
DSM_ThuNDeR - You really should pop the top off of that wastegate to verify which spring it really has. Otherwise, you're only guessing how much boost you're supposed to be running. I wouldn't trust what it was 'claimed' to have came with, because it's easily possible that it has something other than what you think is in there. Also, your really should shorten up that vacuum line to the wastegate. Run that line from the manifold directly to the BOV only. Then run a separate line from the turbo's compressor cover or lower IC pipe directly to the lower port of the wastegate.
Is it currently spiking, creeping, or just running high? Did you do any porting on the volute of the turbine housing?
-Paul Volk-
'99 GSX
'91 TSI
Visit 99gst_racer's homepage!  View photos of this member's car
Old 11-17-2009, 01:25 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
gofer's Avatar
Tech Posts: 230
Photos: 11
Classifieds Rating: 0
Reputation: gofer is an unknown
youve got so many miles of vacuum hose that it wouldn't matter if youve got a 10psi spring in that external wastegate... jk
alright heres what Paul is talking about. you need a boost source as close to the compressor of that 20g as you can get. that way as soon as you go into boost that tial will see it and open up ASAP to control it.
in the lime F&F green is the routing of my vacuum lines for my wg and my bov. i have mine actually zip tied to my radiator, not floating around in space by the exhaust mani but hopefully you get the idea. if you don't have anything to hook up a hose to on your licp what alot of guys do is screw a nipple into one of the couplers instead of going through the trouble of welding one on a pipe. just do a BLT after the install!
hopefully we were able to help?
-Corey
97 Sorano Red A/T GST converted M/T GSX
Visit gofer's homepage!  View photos of this member's car
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tial MVS 38mm o2 Package SPECIAL! punishment Vendor Announcements 6 08-25-2009 07:42 PM
Tial MVS 38mm wastegate/atmosphere dumped o2 housing package punishment Vendor Announcements 5 03-23-2009 02:02 PM
Just got Tial 38mm Wastegate Itlooksfast Newbie Forum 19 08-09-2006 02:35 PM
Tial 35mm and the Tial 38mm wastegate.... clipise Turbo System Tech 2 01-27-2006 06:01 AM
tial wastegate won't open (38mm). help!!! v8s_are_slow Newbie Forum 5 10-29-2004 12:34 PM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
Possibly buying a new 1G
by: booostedGSX
» Recent Tech Threads
Title, Username, & Date
1980's HKS bov
by: bransonauction
2.5 stroker
by: Hittman92
aem wideband install
by: kidtsi
Evo 8 Ecu In 2g Works!!
by: GSXDNA
dsmlink tuner in oceanside, Ca.
by: doctor_shock10
» Latest Gallery Photo
User 1kwik4g
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 38.10%
8 Votes
16 Votes
6 Votes
Total Votes: 21
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
