B-lackGSX99
- 112
- 2
- Nov 9, 2006
Edmonton,
Okay, so if I go for a solid speed run, I noticed that as soon as I hit max. boost (set to 16lbs in my car) and the wastegate opens up, my rpms no longer want to increase. Typically, this happens at around 4500rpms. Is this normal??
What kinds of things can I do to adjust the boost so that it allows me to get to redline? I feel like i'm missing out on almost all of the powerband that I worked really hard to achieve with my 272/272 HKS's. For the time being, i'm going to re-read the vfaq on tuning with the SAFC-ii and see if there is anything I can do from that end. I've also heard about using different trims, but have no idea what this is...
I look forward to your ideas/comments/suggestions.
and the wires? To what are the gaps set?
