1993eclipseGS
- 3,751
- 76
- Aug 30, 2002
NE,
Pennsylvania
First off, I would like to say I searched for a few days, Reading old and new threads, Googled pages etc. I am very confused and now have a major headach as I am stuck on what to do. There are so many turbo's out there, It really is hard to pick just one particular turbo, The going to picking the vendor to drop all the money with. I just do not know where to begin.
Before I begin listing my mods, I would like to say that the car has all the routine maintanace done including a new head/heagasket/sidecover/ etc.
My car/mods:
1995 gst
6bolt swap
new head (Exhaust side gasket matched)
FMIC w/ short route piping
act 2100
fidenza flywheel
2 1/2" o2 housing
3" o2 housing back exhaust
walbro 255lph fuel pump
ported 2g manifold
aeromotive afpr
Fic 850cc injector
Apex'i Safc
eprom with dsmchips chip with andymoraitis' help on all the good stuff to get.
hard intake pipe
I aso have the intake manifold off the car as I was looking to purchase a SMIM and would like to drop in 272's in the next month or so.. So please keep that in mind.
I'm pretty sure i got the more important stuff down, The obviously mods as in a boost gauge etc I did not list because I would think the people reading this would know that I already have that stuff..
As for my goals? Well, To be honest i'm not really sure. The car is a street driven car and see 94pump gas and will occasionaly see c16 when I feel like spending the money on it. I'm looking to make over 350whp as a definate and do not really want to get a 16g, That is for sure. I was looking at bigger turbo's, Internally gated but there are so many on so many different sites that I can not really decide. I'm not asking you to pick a turbo for me, I'm simply asking for " good advice". I do not need to hear anyone flaming/bashing me in this thread as I see no reason for it. I also don't want the whole thread flooded with the new slogan " a 50 trim seems right for you" and that is all the post says! Now, I know there is also alot of these threads showing up, And alot that has been outdated already. I read MOST all of them already, So do not compare this thread as just another I don't know what turbo to choose thread.
Thanks alot.
My car/mods:
1995 gst
6bolt swap
act 2100
fidenza flywheel
2 1/2" o2 housing
ported 2g manifold
aeromotive afpr
Fic 850cc injector
Apex'i Safc
hard intake pipe
Thanks alot.
! But not because of the obvious. Yes a 50-trim wheel will flow what you want. But remember that the hot side has much more to do with spool than the conpressor. I know that you know that you should not base your decision on spool characteristics heavily on the compressor diameter, weight, flow, housing size. The turbine wheel and hotside a/r number is much more important. But I do say that a 50 trim compressor wheel is ideal here. as you're wanting more than 350 hp but "not sure" how much more. The high efficiency of the 50-trim wheel lends to its veratility. That is its true advantage, IMHO. You can run stock cams and 20 psi and still be over 75% efficient or run 30 psi and 272s/FP2s and look at +70% efficiency. It is incredibly versatile. Your hotside is your choice. What is streetable is up to you. And that is a hotside choice, IMHO. Overall VE may not be worth a 4500 rpm spool. But anything w/ a 50-trim compressor wheel should satisfy you. . . .
