50 trim low pressure actuator..
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
hey guys,
for the first time in 6,000 miles I've turned down the boost on my 50 trim (to break in the head, etc.) I noticed that I DID NOT get the high pressure actuator as I thought I did. I'm currently only hitting 8 psi and creeping to 12 psi (that's WITH porting).
my question is, if I upgrade to the higher actuator, will it be worth it? I will be boosting 20+ this coming spring :)
If the low pressure actuator is set to only 8 psi, then it will definitely be worth it to upgrade to the higher actuator.
