got-psshh
- Nov 25, 2004
Cincinnati,
Ohio
Hey i was justwondering if the reason maybe my oil pressure is dropping so low is because i do not have a oil cooler.. I know that turbos produce a lot more heat than N/t, b/c its only way to cool turbo, but i mean. its going from like 80.. all the way down to about 15... this is after if runs for a while at idle. when i get up on it, it gets up to maybe 50... Do i need a cooler will this all go away?
