Brett99GST
- Sep 22, 2004
Point Pleasant,
New Hampshire
Ok, heres the deal. I just put my exhaust on tonight thanks to Kenny (Props). Heres my setup. Ported 2G mani, Ported Evo 16G, O2 dump, full 3 inche turbo back, Hallman MBC. I have 2 exhaust leaks because of missing gaskets. First one is the O2 housing gasket and it is a pretty bad leak, second one is where the muffler bolts to the axle. and im not sure how bad that one is, probably just as bad. Car is runninhg super rich. Have walbro fuel pump, stock 450's and no AFC on yet. I had no creep at all on stock exhaust. Put the 3 inche on and my boost is running away past 20 PSI. Its boosts 13 till i hit 4 grand then just runs away. I set the MBC all the way as low as it would go and I know it was working cause i had it set to 15 right before I did the exhaust. I double checked all my BC lines. Have a first gen blow off valve, have the boost source tapped to the vaccum line between the BOV and Intake mani. Other line runs to the wastegate. All lines are on and didnt pop off. I am stumped. Jess has the same setup as me and doesnt creep. Same turbo and all. Is there anyway that my exhaust leaks could be causing creep?? Im am bummed that now I cant get tunned tommorow. Any help would be appreciated. Thanks!!!
