PMS'n
AlmostStock TSi
36
Aug 19, 2002
W.F., Texas
how many people on here use, reccomend, dont reccomend, efi systmes pms on a 1g awd? how hard/time consuming is it to tune w/o a dyno?
I have it.. The best part if the removal of the stock MAF and using the 3" Hotwire setup. IT took off a couple hundred rpms off my spool time. I had only time to play with the fuel side of the unit. The drivablitly was better than my AFC. It did not run as rich (blow black smoke) when you got from part throttle to WOT. The pms can compensate more with the way the fuel tables are setup.
