Jesse
- Dec 31, 2002
Allentown,
Pennsylvania
This problem has been happening for a while but just recently started to get worse. I can be driving the car and all of a sudden when i go to accelerate i'll get about 40 knock, and if i stay on the gas pedal the turbo will spool but the car won't go. Then i'll let off and do it again but this time it runs fine and the car takes off like it should all the way to redline.
Things i have tried: fuel filter, stock injectors back in the car, fuel pump has pressure, ignition coil, spark plugs and wires, pcv valve, cleaned the air filter, disconnected the o2 sensor, ecu, fuel pump relay, new knock sensor about 2k miles ago.
I am pretty sure it's not a boost leak because the problem only occurs once every five times that I accelerate. The motor also has fresh lifters and does not make any noise.
Any help will be appreciated.
Thanks,
Jesse
Thanks,
Jesse
