blewbyu
- 54
- May 14, 2002
Does the screw on the bottom of the MAS have any effect on top end being lean? How about the adjustment screw on the throttle body?
I cannot get my car to stop running lean over 5000 rpm.
I have a 97 gst with a TD05, greddy evo 3" catback, 3" high flow cat, hk34 bov, rc 550's, walmart 255 pump, hc's removed, injen intake, s-afc. I'm running 15 psi boost, which is as low as it will go.
Setting my afc higher gets me nothing but faster fuel cut. Should I shoot the car and start over?
