what is tunersteins problem
Cnock
106
Feb 28, 2003
Trenton, Michigan
i bought a logger cable and software off ebay and tried hooking it up to my car the other week. everything hooked up fine till i tried to run the software and everytime i do it says missing dll. well i had my friend who is pretty nifty with compueters help me out and he couldnt figure it out either so i decided to go the links the directions provided if i needed help but all of them didnt exist. so now im mad and decided to email them and so far i have had no response and its been over a week. anyone any input could help. thx laos i am running this off a laptop of that helps and its windows me
Well, you got ripped of. The tunerstein software is freeware now, anyone can download it from their site. However, they are no longer providing technical assistance to the people who use it, since they have made it freeware.
....Kyle T.
well it was real cheap i mostly just paid for the logging cable and he gave me the software free but its all jacked up.
Tunerstein doesn't have a problem. It is most likely a setup issue on your end. They no longer support the product or sell it. The makers concentrate only on dsmlink now.
My advice would be to remove what you installed off your logger and then re-add the 3 files needs to make it work.
I opened up my zip file I purchased a few years ago from Tunerstein and it had the following files that had to be uploaded to the Palm Pilot in order to work
Dtc.pdb -- database CHECK engine light codes
PNSTein.prc -- Tunerstein program itself
Reg.pdb -- The registration info. I'm not sure if this is used anymore since it's freeware.
You should first update or at least verify your Palm has the most current software running on it and is it a 3com Palm? He doesn't support Visor or any other makes of Palm's.
You can update your Palm (3com) at http://www.palm.com
Start with the basics before you blame. It could be something simple.
