South Texas summer + Front mount = ?
Wobble
726
Jan 2, 2003
I have a dejon tool FMIC and a stock radiator..
my car runs DEACENTLY cool just cruising around town.. the needle stays about half way.. LITTLE just banging around not hitting full boost (18psi) but when i get on it HARD.. i.e a 2nd and 3rd gear pull from 35 to 100mph it heats up a bit.. from about the 9 oc position to maby 10:15 nowhere near the "warning mark" it does it worst if i hit it hard then let off to an idle.. if I just let it coast down and keep the revs up (let 5th drag it down) it rises less..
this is in 85-95 degree heat with 89-90% humidity..
I doubt the temps im seeing will harm the motor, but it bugs me none the less..
Ive started replacing all the air ducting that i pulled out for the FMIC install, Im having to remake it with neopreen rubber.. so far i have to TOP but nothing else.. it seemed to help SOME but it still gets a tad warm..
I know the obvious solution is a bigger Fluidine, Koyo or PWR radiator.. but thats a good chunk of change right there, plus trimming my damn fans..etc
so far im looking at 3 more possable solutions..
1: Redline Water Wetter. my friend swears by it and it seems to do good at dropping a good 15 degrees or so..
2: reconnect my oil cooler.. i bypassed it when i did my head swap.. I figure MABY the extra volume of coolant will help some... MABY..
3: Finish ducting.. im doing this assuming the hurricane doesent wipe me out tommorrow (dead smack in path) better flow around the core always helps...
anyone here from TX running a FMIC? your reactions? torments? anyo other ideas in general?
I know alot of people say not to do this, but try putting in a lower temp thermostat, and also drill a few small holes in the plate so it will get better cooling.
Then you could also run higher water like 70% which will give you better cooling for summer driving.
I also say wire your fans onto a switch so you can turn them on and keep everything cool.
wow, this storm is intense.. the eye is like 60 miles away and heading this way.. and where is UPS with my springs dammit?! LOL
yea, i already have a 180 degree thermostat in there, havent drilled any holes yet though..
try running a fan switch so you can turn on the fans, i ran my car this way for years it works the car runs at 180 deg
I'm running a Fluidyne with 1 stock fan nd 1 spal fan. I'm not sure, but my gst came with a 180 thermastat. My temps with A/C on cruising are around 213-216. I'm sure they would be lower with some water wetter..I like Royal Purple ice. I wouldn't go to much my the stock gauge, but I do know that when mine was exactly half way, the temps were around 229-232.
i try to keep my temps under 215. becuase oil temp gets really if the tempstart getting to 230 and more.
i have a Oil temp gauge and water temp gauge. The factory one is not the most accurate at all.
Originally posted by nine5raptor
I run a 170*, so you may try an even cooler one.
this keeps me running around 193-203. with a new 180, I went from the 235ish range down to 220's not good enough. that is why I put in the 170. My timing is much better now.
