boostin
- 59
- May 10, 2002
Omaha,
Nebraska
My logs from tonight are f*ucked up. First things first - main mods are big28 turbo, 550's, Walbro 255, still have stock side mount. OK, I kept leaning my car out, because timing kept advancing and when I started out, it was peaking at about 24 deg. However leaning it out didn't improve my mph at all. What it did do was advance my timing sky high- on my last run, timing was at 21 at the start of 3rd gear, steady incline and peaked at 27 deg
Unfortunately I don't yet have an EGT. I guess my question is what the hell is going on, my AFC settings were at -45 in the lower rpm up to -37 at 7k. I'm afraid I might be detonating because my settings are so low for 550's, but I'm not getting any knock. Also- why is my car not running any faster?
