Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 07-25-2002, 09:41 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 91gsx is an unknown
egt/o2 readings are arguing
on a 2nd/3rd run tonight attempting to do a quick tuning session, at the top of 3rd gear my egt's hit 1600 * F (after some afc adjustments), but my 02 reading only went up to .82(after the same adjustments). i know that o2 isn't really an effective way to tune, but shouldn't they follow a little closer? correct me if i am wrong but shouldn't the o2's be around .88-.92? i know that i want to be around 1600*F peak as far as egt's go. any help would be greatly appreciated.
ps my timing went from 18-20, stayed & crept up to 24 as the rpm's increased. i know i want to be around 20ish, 24 shouldn't hurt much,,,correct?
my knock count spiked to 1 once, other than that all 0's through 2nd & 3rd.
Offline
Related Auctions
Sponsored Links
Old 07-25-2002, 09:50 PM   #2 (permalink)
Site General
Car: 01 Trans-AM WS6
Region: Southwest
Classifieds Rating: (4)
If the timing is good,they car is pulling and EGT's aren't melting stuff. Forget the O2's. Every car is different, I pull like a mother and ny O2's are .94 and .96
Later,
____________________________
John-
Online
Old 07-25-2002, 09:53 PM   #3 (permalink)
Proven Member
thanks for the reassurance, i just thought .82 was really low
Offline
Old 07-25-2002, 10:22 PM   #4 (permalink)
Proven Member
now as i reset my mbc back to 18psi (from 14psi) i can expect for a leaner condition, correct?
Offline
Old 07-25-2002, 10:47 PM   #5 (permalink)
Site General
Region: Southwest
Yes becasue you increased boost and didn't change fuel. Depending on you pump and injectors it may not change that much. But you will probably need to add a little fuel to be safe.
Later,
John-
Online
Old 07-25-2002, 11:27 PM   #6 (permalink)
Proven Member
thanks man
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11397290 seconds (73.33% PHP - 26.67% MySQL) with 9 queries
