AWDBurn
- 38
- May 19, 2003
Roanoke,
Virginia
I got a 2G manifold with my Apexi EL EGT tapped into the #1 runner.
what kind of temps do you guys think are lean when tapped in that position?
I'm hearing of guys running 910 and saying that is perfect in that position and also in the Downpipe position. which is it?
I know that the exh temp changes like 10 degrees for every inch away from the output of the head, my guage is tapped at about 1.75" away from the that outlet.
I really need to know what I should look for, I'm pulling no knock at 930 and .87 volts, but I think my 02 sensor might be starting to go bad.
What should I look for when punching it?
what should I look for when driving highway speeds at 70mph?
so far I've been at 890 to 910.
I have another spot on my triple Apillar to put another guage, I'm think that another EGT in the DP might be a good idea, might help with tunning and would be interesting to see the differences.
Thanks for the replies
