MAFT what settings do i use with this translator?
badboyr66
918
Dec 8, 2002
eastern, Washington
:cry: Ok finally got my translator, and upper IC pipe from dejontool. I am not sure what to set this at right now. I do not have a pocket logger yet, so it is all by feel. Car is basically stock with exh and 14 psi. It just does not take off like it used to plus it idles at like 2k. If anyone has any insite on what to set this at would be of great help
[email protected] :talon:
keep the base setting for 450s. Then try richening up the idle some, and leaning out part throttle. What you ahve to realize is that after every adjustment, you must allow some drive time. I found wiht mine, that when making changes, it would reset the ecu. Keep your adjustment minimal...one click at a time, and drive it for a bit before testing. Dont give up. It took me a week to get mine dialed in really good.
