mitsugsx95
- 707
- 2
- Sep 27, 2002
Illinois
here it is on my 16g @ 12psi. (3rd through 4th pull)
rpm o2volts timing
2380 .80 18
3352 .96 7
4940 .96 10
6572 .70 18
4940 .96 11
5620 .94 15
6304 .94 18
5852 .94 18
My timing was pretty steady through the whole run. and the o2 volts were holding around .95. This is with the stock inj and the safc on 0's through the hi th. This is my first pull, so im just looking for input on how it looks. What is normal for timing? Should it be advancing?
rpm o2volts timing
2380 .80 18
3352 .96 7
4940 .96 10
6572 .70 18
4940 .96 11
5620 .94 15
6304 .94 18
5852 .94 18
