2nd and 3rd fear log on 60-1 S trim
nowayout
680
Jul 17, 2002
green bay, Wisconsin
this is at .9 bar of boost (13.75 psi) 93 octane GAS base fuel pressure 43 psi hose hooked up. running 90% inj cycle at .9 bar.
Time RPM Knock Timing O2 Airflow Inj P/W Air Temp TPS
00:39.4 3125 0 30 0.82 479 6.41 67 65
00:39.6 3281 0 29 0.92 523 7.179 67 79
00:39.9 3469 0 29 0.9 567 7.436 67 82
00:40.1 3656 0 28 0.88 617 7.436 67 84
00:40.3 3875 0 27 0.88 706 8.718 67 85
00:40.6 4125 0 26 0.88 882 11.282 67 86
00:40.8 4406 0 24 0.88 1121 13.846 67 86
00:41.0 4625 0 21 0.88 1304 15.385 67 86
00:41.2 4844 0 22 0.88 1361 15.128 67 86
00:41.4 5219 0 23 0.88 1474 15.897 67 86
00:41.6 5438 0 23 0.88 1588 17.179 67 86
00:41.7 5625 0 23 0.88 1607 17.436 67 86
00:41.9 5812 0 24 0.88 1607 17.436 67 86
00:42.0 6125 0 25 0.88 1607 17.692 67 86
00:42.2 6188 0 23 0.88 1607 17.436 67 86
00:42.4 6469 0 20 0.88 1607 17.179 67 86
00:42.5 6438 0 21 0.88 1607 16.923 67 86
00:42.7 6562 0 21 0.88 1607 16.923 67 86
00:42.9 6812 0 21 0.86 1607 16.154 67 10
00:43.1 6438 0 39 0.88 290 2.051 67 10
00:43.3 5719 0 45 0.8 239 5.641 67 83
00:43.5 5094 0 27 0.88 901 10.256 67 93
00:43.8 4656 3 25 0.88 1103 13.59 67 94
00:44.0 4781 3 20 0.88 1310 15.128 67 95
00:44.2 4875 2 21 0.88 1329 15.128 67 96
00:44.3 5000 2 21 0.88 1367 15.128 67 96
00:44.6 5094 2 22 0.88 1418 15.385 67 96
00:44.8 5250 1 22 0.88 1468 15.897 67 97
00:45.0 5344 1 21 0.88 1512 16.41 67 97
00:45.1 5469 1 22 0.88 1562 16.667 67 98
00:45.3 5500 0 22 0.88 1607 16.923 67 99
00:45.4 5562 0 23 0.88 1607 17.179 67 99
00:45.6 5719 0 23 0.88 1607 17.436 67 99
00:45.7 5781 0 24 0.88 1607 17.436 67 99
00:45.9 5844 0 24 0.88 1607 17.436 67 99
00:46.1 5906 0 24 0.88 1607 17.436 67 99
00:46.2 5906 0 25 0.88 1607 17.179 67 99
00:46.4 6031 0 24 0.88 1607 17.179 67 99
00:46.5 6188 0 25 0.88 1607 17.179 67 99
00:46.7 6219 0 24 0.88 1607 17.179 67 99
00:46.8 6156 0 22 0.88 1607 16.923 67 99
00:47.0 6438 0 22 0.88 1607 16.923 67 99
00:47.2 6250 1 21 0.88 1607 16.667 67 99
00:47.3 6500 1 21 0.88 1607 16.667 67 99
00:47.5 6469 1 22 0.88 1607 16.667 67 99
00:47.7 6625 0 22 0.88 1607 16.41 67 99
00:47.8 6656 1 21 0.88 1607 16.154 67 70
00:48.1 6656 1 27 0.86 1027 2.308 67 10
Considering this is all new to me this is what I see:
Knock = VERY good
Timing = good
O2 = can't remember 1G specs... but I think it's on par
I need bigger injector or I have to up the fuel pressure to 50 or 55 psi at idle to see if I can get a little out of these injector on pump gas.
Right now I'm just running off the waste gate.
This turbo flows a lot of iar so I have to be very care on turning up the boost.
I agree with the new injectors... what size are you running at the moment?
I wouldn't suggest bumping the FP since you are close to running max pulse width as is.
That turbo probably flows more at idle that I do at full steam!
There goes another $500 in the hole.
I thinking 720 will be enough fot about 18 psi on pump gas.
