log on my new setup any suggestions.
nowayout
680
Jul 17, 2002
green bay, Wisconsin
Here is a 3rd gear pull on my new set up. EGT is under 800CC
Time RPM Knock Timing O2 InjP/W throttle 03:48.0 3812 0 31 0.88 6.154 50
03:48.2 3875 0 30 0.88 6.923 56
03:48.5 3906 0 29 0.88 7.692 59
03:48.7 4000 0 27 0.88 8.974 59
03:48.9 4125 0 26 0.88 11.026 60
03:49.2 4219 0 24 0.9 13.333 60
03:49.4 4344 0 22 0.9 14.872 60
03:49.6 4469 0 21 0.9 15.128 60
03:49.8 4594 0 21 0.9 15.128 61
03:50.0 4656 0 21 0.9 15.128 61
03:50.2 4781 0 22 0.9 15.128 61
03:50.4 4906 0 22 0.9 15.385 62
03:50.6 5000 0 22 0.9 15.385 62
03:50.7 5094 0 23 0.9 15.385 62
03:51.0 5219 0 23 0.9 15.897 62
03:51.1 5344 0 23 0.9 16.154 62
03:51.3 5375 0 23 0.9 16.41 63
03:51.5 5562 0 23 0.9 16.667 63
03:51.7 5562 0 24 0.9 16.667 63
03:51.8 5750 0 24 0.9 16.667 63
03:52.0 5719 0 25 0.9 16.667 63
03:52.1 5875 2 24 0.9 16.41 63
03:52.3 6000 2 26 0.9 16.41 63
03:52.4 5938 2 25 0.9 16.41 63
03:52.6 6156 1 25 0.9 16.41 63
03:52.8 6094 1 27 0.88 16.154 63
03:52.9 6188 3 25 0.88 15.641 23
This is not a full throttle yet I'm tuning it slowly in and at .9 bar (13.75 PSI) of boost.
I hope I can get some 7000 rpm runs tomarrow?
It seems like the 660 are running at 80% at about 6K rpm.
Hmm, I think a log is really useless if it's not done at WOT. Otherwise the ecu could partically still be in closed loop mode, you don't see what your timing bottoms out at when boost hits. The only time I don't log at WOT is if I'm looking at fuel trims. I would say re-run it at WOT.
