kingearl
- 209
- Jun 6, 2002
Edmonton,
I just replaced my stock injectors with my 625's. The car runs all the way down to -30% across the board on the AFC before it stalls but runs like junk unless its up around the -5% mark.
Anyway I set it up I have crappy acceleration until 3k RPM. I mean like hardly moving till that point. Then it takes off like stink.
Since I put them in I am getting way more knock. A bit more at idle, quite a bit more at normal acceleration and anything more then 11 pounds of boost send the knock pass 43 count. WTF!?
I wouldn't think the car would run so crappy just by installing these. What would help me out? AFPR? I need a new o2 sensor, I know that. But what is the problem mostly?
