fuel trims 100% ???????
PushinPsi
35
Apr 1, 2003
my fuel trims are a constant 100% low mid and high
even when im getting (max30)knock at 4500rpm
does this mean my ecu is running in closed loop?
or like a get home safe mode?
beacuse im throwing a code 21 coolent temp senser, and i think my isc is shot (bad idle while rolling to a stop in neutral)
any ideas i have more info if it helps..
thansk tyler
RIGHT?
cause if it was knocking, the ecu should send as much fuel as possible (140%) , but its not.
till i figure it out i have my car set to 12psi only seeing 1 knock count
while im crusing or at idle is my timing suposed to be at ~30deg?????
under boost it sits at ~18deg
~18ms injectors how do i trans late this into duty cycle???
THE 18- 19MS I SAW WAS AT ABOUT 5K RPM AT 18PSI
NOW I HAVE THE BOOST SET AT 12PSI FOR NOW AND I STILL SEE 18MS AT AROUND 5K
IM WAITING FOR MY FMIC AND TB ELBOW, AND THEN ILL BEGIN MY JOURNEY OF TUNING TO ~20PSI....THAT IS IF MY INJECTORS WILL TAKE IT.
AND CODE 21...COOLENT TEMP WILL BE FIXED SOON,THIS IS MESSING WITH THE CAR BAD
I think that the coolant temp sensor bad will definitely affect your ECU in how it selects fuel and timing. Coolant temp, I would imagine, is a factored variable for computing that stuff.
I say get that coolant sensor fixed, then re-log.
-M
WILL DO, I JUST STARTED SCHOOL THIS WEEK SO IVE BEEN BUSY, ILL LET YOU KNOW WHAT I FIND.. I DO HEAR A HISSING FROM THE INTAKE MANIFOLD BUT I CANT FIND ANYTHING YET...AND THE TEMPSENSER IS ON THE WAY..BROKE FOR NOW
WHAT TURBO ARE YOU RUNNING? WHAT WOULD A ADJUSTABLE FPR HELP?
MY CURRENT FUEL SET UP
16G
550 RC'S
255 WALBRO
MAFT 3.5IN MAS
TMO DATTALOGGER
FOR A BOOST LEAK TEST
CAN I PLUG THE INLET SIDE OF MY TURBO, T IN A BIKE PUMP TO A VACCUM LINE,AND PUMP PUMP PUMP, AND HOPE IT HOLD THE PRESSURE,????
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
