Al Blaha MAS
GiRtHyTaLonTsI
30
Oct 1, 2002
New York
is any one running an al balha mas....i just instaled one from turbo trix and i removed the flapper door and tried tuning my afc to hold a idle.....its hold a idle but a very low one and the idle is a lil choppy....any help will be useful :D
I'm at 30% (Als recommendation) for 550s.
I've heard too many horror stories about flapper doors falling off and meeting their maker in the turbo. Better off w/o it.
You're going to have to crank your AFC waaaaaaayy the heck up at the lowest RPM setting, probably to +50% if you're on stock injectors.
You're also going to need a LOT of positive correction across the board, although not as much as you need at idle.
thanks alot guys for the info im gonna try that as soon as i get off from work :thumb:
