KrazyRob
- 77
- Mar 19, 2012
MODESTO,
California
I have a 99 GSX with 55k miles on it and it runs like crap now
Ok where do I start..
I bought this GSX earlier this year here in CA and it had a bunch of illegal mods on the motor and a blown head gasket, So of course it would not pass Smog so I could get my 2012 tags.. I am a auto/equipment mechanic so I did the head gasket/ timing belt job and changed it back over to make it legal/ or some what legal
to pass smog.. The main problem was the visual of my car when you open the hood, it had a Chrome Header with external waste gate, a GM MAF AND MAF TRANSLATER, ALSO HAD A GIANT SHINY 50 TRIM TURBO on it, chrome piping and large Blitz BOV.. it had large 680cc injectors.. and FMIC..
Ok so I got rid of the 50Trim turbo and installed a rebuilt HMI EVO 3 16g turbo, as it looks more stock than the Giant chrome 50 trim but now I have a J-Pipe
.. anyway I put back the stock exhaust manifold and got rid of the chrome piping, installed the stock maf and stock injectors back in the car. I tapped a nipple from the J pipe to the new internal wastegate and ran a short vacuum hose.. The car looks alot more stock when you open the hood, but it has alot less power now..
I have been driving the car the way it is for about 4 months now and it gets from point A to Point B but you can tell it is not tuned..
The problems I am having are..
Runs Rich (you can smell the exhaust) I dont have a wideband or boost gauge
Dies out some times when the throttle is let off (possible boost leak)
Horrible on Gas MPG
Gets fuel cut around 6500 RPM
Takes a while to spool, almost like there is too much fuel or timing is retarded (dont have that instant power that I had before)..
This car has always run on stock boost, but it was tuned before at a shop to run optimal with the components it had as far as A/F.. Now I have mix matched components some stock some after market and its just not running right.. Its almost like I want to put back the GM MAF, MAF Translator, big injectors ect and see how it runs with that 16g..
I also have a new Wally 265 fuel pump that I have not installed yet.. I want this car to be a "sleeper" and look stock but be fast as hell.. I also need to decide how far I want to go with the mods because every 2 years I will have to put it back stock for a smog check.. Any where in Nor Cal /Central Valley where I could get this car tuned?
Also off the subject but... how are these AWD cars in the snow? I was thinking about taking it up to Lake Tahoe this weekend and its snowing... It never snows where I live
..Ok where do I start..
to pass smog.. The main problem was the visual of my car when you open the hood, it had a Chrome Header with external waste gate, a GM MAF AND MAF TRANSLATER, ALSO HAD A GIANT SHINY 50 TRIM TURBO on it, chrome piping and large Blitz BOV.. it had large 680cc injectors.. and FMIC..Ok so I got rid of the 50Trim turbo and installed a rebuilt HMI EVO 3 16g turbo, as it looks more stock than the Giant chrome 50 trim but now I have a J-Pipe
.. anyway I put back the stock exhaust manifold and got rid of the chrome piping, installed the stock maf and stock injectors back in the car. I tapped a nipple from the J pipe to the new internal wastegate and ran a short vacuum hose.. The car looks alot more stock when you open the hood, but it has alot less power now..I have been driving the car the way it is for about 4 months now and it gets from point A to Point B but you can tell it is not tuned..
Horrible on Gas MPG
That is the only other reason I can see... Though I am going speed density so I can put the intake just behind the front bumper, so I will be venting just because of the additional plumbing hassle. Plus, there is going to be a big water intercooler blocking the easy routing, unless I put the BOV right at the turbo outlet, and its a bit tight there already... But anyhow, nevermind me.
