jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
Well, since my gauges were stolen, I am in the market for new gauges. My question is how accurate is the s-afc at reading o2 voltage. I remember reading that the blue wire mod is a bad idea, when taped in to the ECU. but what if you connect the s-afc's blue wire to the under dash o2 wire commonly used for a pod mounted a/f gauge.
1) is the S-afc accurate enough to use for a/f monitoring
2) Can the blue wire from the safc be connected to the o2 wire that's under the passenger kick panel on a 1g?
