imdrax
- 172
- 1
- Aug 7, 2003
napa,
California
First off I would like to know if anyone on here is running MMCD on their GVR4 and if so is it fully compatible? From what I know the ecu's between a 1g DSm and a GVR4 so I'm assuming the information I am seeing on the logger is accurate. This brings up some major issues.
So after a quick log I found some interesting things.
1. MMCD shows my tps to be at 12.8% at idle ALL THE TIME. whether hot or cold its reading 12.8% at idle. My afc shows a TPS voltage of .65v at idle. Not sure whats going on here
2. For some reason MMCD shows voltage for F & R O2 sensors even though the GVR4 has only the front. The weird thing is they both provide a constant voltage signal to the logger. The "front" O2 is sending 2.5v and the "rear" O2 is showing .5v, neither of which are cycling. This leads to my next problem.....
3. My fuel trims are all at 100%, L M & H. Even the o2 trim is stuck at 100% and is not cycling, I believe this is due to a faulty O2 sensor. Confirmation?
4. I am getting an intermittent CEL, it comes and goes sometimes more thn once during one short drive. I looked up codes on MMCD and I BELIEVE( if i read the logger right because I am using v1.8 which is new to me, im used to the old MMCD) that I am storing codes 21 & 31 which are ECT sensor and Detonation sensor, respectively. This leads once more to my next question....
5. I logged a small acceleration in 2nd gear from about 2000rpms to about 3500rpms(let off due to stuttering really bad) and got anywhere from 5-10 up to 25 counts of knock. No bueno. I will be checking the knock sensor tomorrow for goo.
To sum up, the car idles fine, drives ok, coasts at 2krpms until stopped, the tps is supposedly stuck at 12.8% throttle when the accelerator pedal is not depressed, stutters under heavy acceleration, provides no O2 signal, fuel trims are stuck, knocks under almost any boost, and throws codes 21 & 31. Phew what did i get myself into this time.
What is everyones opinions on some or all of the issues presented, and their ideas of possible causes and solutions.
