Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Tuning & Engine Management
Tuning & Engine Management 4G63 EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 09-02-2009, 09:27 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 1,187
Classifieds Rating: 1
Reputation: NOSLO2PT0 is more helpful than not
Spoolinup AFPR issues
Anybody else have any experience with these? Not sure if this should go here or in the parts review, so mods, if necessary, please move to appropriate forum.
These haven't been made for quite a few years. They were popular back in the early 2000's when a bolt-on AFPR wasn't really available. They were probably the first to do so outside of Buschur's bulky bolt-on regulator.
I'm chasing down some widely ranging AFR's and this could be one of the culprit pieces. Had the base fuel pressure set at 45psi. Cruising around, the AFR was a steady 14.7:1. AFter doing a hard pull, the AFR's were bouncing around anywhere from 15.9 - 17.8!!! Car shouldn't even be running at 17.8:1, but it was cruising fine. Got home, checked fuel pressure, and it mysteriously dropped down to 41psi. Turned it back up to 45, but the AFR's still didn't line up like they did before.
I had one of these units years ago, and the guy that bought it off me was having the same problems. Couldn't keep the fuel pressure at a constant level. Kept having to increase it to get it where he wanted it. He said the internal spring was giving out. He eventually just sold it.
Has anyone had one of these units and had the same issues of fuel pressure falling off? Just looking for some input on this unit and people's experience.
____________________________
Mike
Visit NOSLO2PT0's homepage!
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 09-02-2009, 11:32 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
DSM Wiseman
steve's Avatar
Tech Posts: 8,500
Photos: 12
Classifieds Rating: 15
Mine is in my tool chest because it didn't look like it was tracking manifold pressure 1:1.
I don't know if they were build to work with E-85 either. Ethanol at E85 levels can impact various metals like aluminum, plastics and rubber.
Visit steve's homepage!  View photos of this member's car
Old 09-03-2009, 07:07 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
logic's Avatar
Tech Posts: 670
Photos: 6
Classifieds Rating: 2
Reputation: logic is pretty helpful and trustworthylogic is pretty helpful and trustworthy
I'm with Steve on this one; I'd try disassembling it and check for any corrosion or build-up, and make sure the seals and diaphragm look right; I'd expect a bit of swelling on any seals, at the very least. If memory serves, those things were just bare aluminum assemblies, right?
-Ed
Visit logic's homepage!  View photos of this member's car
Old 09-03-2009, 07:53 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
jrohner's Avatar
Timeslip: 99.990 @ 11.110
Tech Posts: 1,322
Photos: 6
Classifieds Rating: 0
Reputation: jrohner is pretty helpful and trustworthy
Some of those AFPRs are junk. Get a new one or get a stock FPR. 17.8:1 AFR is still driveable. My car can even idle at a leaner ratio than that, even with the 272 cams.
Old 09-05-2009, 11:05 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 2,352
Photos: 4
Classifieds Rating: 3
Reputation: pneumo is extremely helpful and trustworthypneumo is extremely helpful and trustworthypneumo is extremely helpful and trustworthy
I've experienced the same thing. I think that's why they changed the design. The newer style uses a longer spring which should be more durable.
I had one of the original designs and it eventually got so bad it wouldn't hold 35 psi without the adjusting screw bottoming out against the diaphragm. I'm still using the newer style, no problems yet. If the spring goes soft again I might try cutting open a stock FPR and use the spring out of it.
11.514 on a 14b
10.77 on a GT35
Visit pneumo's homepage!  View photos of this member's car
Old 10-27-2009, 06:28 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Tech Posts: 28
Reputation: jrotten is an unknown
Spoolinup bolt on AFPR rebuild parts?
I bought one of these from the spoolinup jokers back in the day too. It worked well for awhile and then the car suddenly started to run like ass. I figured it was the diphragm or spring but I cant visually see a problem with either when I take it apart. Put the stock reg back on and boxed the AFPR. Id like to get this thing working again but I guess I'd have to pirate rebuild parts from another brand of regulator to fix this one. I am pretty certain that the spoolinup guys used a readily available diphragm and spring and just CNC'd an adjustable housing to fit, anybody know what diaphragm/spring they might have used to build their units? This may be a pointless post, but I have 150 bucks invested in a paper weight right now so its worth a shot I 'spose.
Old 10-27-2009, 07:44 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
DSM Wiseman
steve's Avatar
Tech Posts: 8,500
Photos: 12
It might help if people knew what it looked like. Here's mine disassembled.
The side of the diaphram facing up in this picture actually goes against the seat in the base shown above it.
The aluminum cap fits in/on top of the spring and the adjuster bolt seats into the depression (not shown) and the other end of the spring fits into the metal center of the diaphram.
Old 10-27-2009, 10:05 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
Tech Posts: 2,352
Photos: 4
To add a little info, the pic in Steve's post is the first version. That's the one that tends to loose pressure and go bad.
11.514 on a 14b
10.77 on a GT35
Old 10-27-2009, 10:44 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
DSM Wiseman
steve's Avatar
Tech Posts: 8,500
Photos: 12
Not really the first version. It is one of the last revisions before they tried to make a 2G AFPR.
Old 11-01-2009, 05:29 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Tech Posts: 1,117
Photos: 9
Reputation: Bohrn is an unknown
subscribing.
and adding that mine has suffered a loss of vacuum as well.
I was/have been chasing a driveability issue as well as a random knocksum issue for a while now.
I put a secondary vacuum hose on it, plugged the one that goes to the vacuum nipple on the regulator and applied vacuum to the secondary hose. The regulator would not hold vacuum, and it would show on the fuel pressure guage. It would loose all the vacuum in about 4-6 seconds.
I pulled it and took it apart, but there is nothing visibly wrong with it that I can see. I am a professional mechanic as well, so its frustrating.
A stocker works fine, but pressure is too high due to the Wally pump. Keydiver chip is tuned for 44psi base, so its not cosher right now, but even like this its way better than the on again, off again adjustable one.
If anyone figures out a definitive solution post it up. I like the small size, look and easy of use of this FTaS one, but it doesn't work consistantly.
11.93/117mph, bad driver, old fuel
Visit Bohrn's homepage!  View photos of this member's car
Old 11-02-2009, 12:08 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 2,352
Photos: 4
It's easier to find a leak by doing a pressurized boost leak test through the vac line. Just use some soapy water and watch for bubbles. Usually the leak occurs at the adjuster screw. A little teflon paste should seal the threads.
If the stocker is working, don't fight it.
My AFPR is still working so I haven't looked for a solution. One idea try is to cut the hat off a stock fpr and see if the spring is the same size as the spoolinup afpr spring.
11.514 on a 14b
10.77 on a GT35
Old 11-02-2009, 06:39 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Tech Posts: 1,117
Photos: 9
its not leaking out there, its bypassing vacuum out the vacuum port.
And as for the "working fine" bit, its not working fine, its just working better than the faulty aftermarket one. And it has the same problem that every other big pump stock regulator 1g car has. The pressure regulator is being over run. Stock pressure is 38 psi. Stock auto pressure is 42 or 44, I forget. This is 58 psi at idle with the vacuum line off. Its not OK, but its also not leaking like the aftermarket one is.
And its not a matter of how strong the spring is, the internal return passages of the stock regulators are too small to bypass enough fuel volume at idle and cruise to properly control fuel pressure.
As well, even if this regulator could work correctly, 58 psi is too high as I am running 27+ psi on my turbo. the math on that is not good. 85psi at the pump. RRE's tables show that as much to high for sustained fuel volume.
Old 11-02-2009, 07:13 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
Tech Posts: 1,187
What kinda pump you running to push your base up to 58psi? A Walbro 255 rewired with an A/T regulator (43psi base) should only push it up to about 51psi at idle. Unless you got something bigger than a 255 back there. 85psi at the pump, and the Walbro gonna take a dump real fast. Actually, the relieve valve starts kickin in around 78-80psi.
Mike
Old 11-16-2009, 08:36 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
this_tsi_8urV8's Avatar
Tech Posts: 286
Reputation: this_tsi_8urV8 is pretty helpful and trustworthy
Relieve valve?
Could mine be semi-closed or blocking the return path?
It's reading about 75psi and I already turned the screw out (lessen pressure) and it's reading the same. I disconnected the fuel pressure return line and read normal. What should I do? Take off the return line to tank and clean it and see if anything comes out? Just replace the return line?
I have a fuelab afpr and have feed line from filter to rail, return line to fpr. I'm thinking about replacing both feed and return lines all the way from the tank.
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Opinions on good AFPR..Megan Racing AFPR? Good or Bad? MarkyGsX Newbie Forum 8 02-16-2009 01:04 PM
Cold weather Aeromotive afpr issues 95 gsx Newbie Forum 5 07-12-2007 12:46 PM
AFPR questions. Starting issues??? Iroc_g Bolt-on Tech 6 01-23-2006 10:34 PM
Aeromotive AFPR Setting Issues GPTourer Newbie Forum 8 05-15-2005 06:31 PM
spoolinup AFPR????? DaBirdtsiawd Newbie Forum 1 06-20-2003 03:55 AM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Seat
by: Spdfreak
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
» Recent Tech Threads
Title, Username, & Date
Holset Bolts loose?
by: fastfive0
power problem... please help!
by: TeclipseFTW
GVR4- Finally hit the 10's to end the season
by: Nate Crisman
anybody know where this wire goes?
by: kneipperk
Need help with TurboXS DSMBC
by: EclipseGst1992
» Latest Gallery Photo
User slowjontsi
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 34.78%
8 Votes
18 Votes
7 Votes
Total Votes: 23
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
