91tizzy
- 459
- 2
- Jan 19, 2008
Cincinnati,
Ohio
The green/yellow wire leading to the harness plug that goes onto the tempertature sensor at the thermostat housing has come off or simply broke from being old and brittle. Can I somehow strip the wire back and reconnect it in the plug....is the process similar to "de-pinning". My o2 sensor has been doing some crazy things lately and Im thinking this may be the answer....wither way I need to fix this and need advise cause Im not a electrical wiz by any means.
