laser92awd
- 128
- Jul 13, 2002
Central Florida,
Florida
Lately I've been playing around with my boost controller and driving the car pretty hard. What's got me puzzled is that if I make a WOT run through 3rd gear, my EGT's peak right at 900C which is pretty high. THIS HAPPENS AT 10PSI! If that's not weird enough, it happens ALSO AT 20PSI! That's crazy. Why would running such low boost make it run as hot as twice the boost?
I have a VPC/550's/fuel pump. I've even tried turning the VPC GAIN knob up and down and it doesn't seem to make any difference.
The car seems to also be running low O2's (around .80 to .82), but I'm not getting any knock, the car pulls hard, and my spark plugs look totally fine. It's almost like I can run whatever boost, set whatever VPC settings, and get the same results.
Somebody was following me the other night when I was testing at 20PSI and they said when I shifted from 2nd to 3rd a huge flame came out my exhaust, but I did not hear any backfire. I also notice when I run at 20PSI it seems like black exhaust smoke poors out the back of the car during the run (like a mist, not like clouds). At 10PSI I don't see it.
What's the deal?
What's the deal?
