evileclipse909
- 391
- 4
- Sep 17, 2007
Colorado Springs,
Colorado
So I finally put link in my car and it starts acting really wired around 5500rpm. I had a friend of mine help me tune it and we discovers that the ecu was not seeing a speed signal which wouldn't allow the car to rev past the launch setting. We set the launch to 8k and the problem went away. But every time the car starts to pull good the check engine light will flash and will display P0500 and the car begins to break up. That's the background of the problem. Also the car was converted from an auto to a 5 speed a year and a half ago. My question is can anybody tell me a way to run a wire from my cluster to the ecu so that I can have a working speed signal again because the speedometer works just fine. Any help is greatly appreciated and I apologize if this is in the wrong area.
