Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 04-04-2008, 09:09 PM   #1 (permalink)
Proven Member
chavez408's Avatar
Region: NorCal
Classifieds Rating: (0)
Reputation: chavez408 is more helpful than not
Dsmlink/ecu issues
Hey guys I just got my dsmlink in the mail with my eprom socket for my 660 injs. And when I put the chip in the ecu and installed it on my car. I tried to turn it on but the car woudlnt turn. I did a it couple times and she fired away but she repeatly died. After a few times of trying she starts but now everytime I try to put it in gear and drive off, it stumbles..
A little background information, the car is still running on the stock injs (450s). And I have not plug the cable to my laptop since I am missing the port. It sounds like it is mis firing. And also I just realise I forgot to remove my batter before removing the ecu, would this cause a problem?
Thanks.
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Related Auctions
Sponsored Links
Old 04-04-2008, 09:14 PM   #2 (permalink)
Proven Member
hdoerr's Avatar
Timeslip: 15.158 @ 92.190
Region: Gulf Coast
Reputation: hdoerr is an unknown
Bro, that just isn't going to work. If you can not control the air fuel mix with the link then your not going to get that thing to run. You need to get that link set and tune from there. Hope that hepls, I doubt it though.
Offline
Old 04-04-2008, 09:21 PM   #3 (permalink)
DSM Wiseman
snowborder714's Avatar
Region: Tri State
Classifieds Rating: (16)
Your EPROM chip is programmed for 660's yet you still have 450's in there. No wonder why it won't start.
You need to go to ECU/Logfile > Fuel and set both your Global slider and Deadtime to 0.
Which means you need to get a Keyspan adapter (since you said you're missing the port - I'm assuming you mean the serial port) to convert the serial cable to a USB input for your laptop.
____________________________
Brian
Offline
Old 04-04-2008, 09:23 PM   #4 (permalink)
Proven Member
Killa_dsm's Avatar
Region: NorCal
Classifieds Rating: (19)
Reputation: Killa_dsm is pretty helpful and trustworthy
Sounds like the problem could be the fact that the link default setting for injectors are 660 injectors and your still running stock injectors. The car would be running lean from this.
Edit: Damn it Brian types faster!
Ryuto
Offline
Old 04-04-2008, 09:34 PM   #5 (permalink)
Proven Member
BoostedTalonTS's Avatar
Region: NorCal
Classifieds Rating: (15)
Reputation: BoostedTalonTS is pretty helpful and trustworthy
Yep, try resetting the link for the stock 450s. If that still doesn't work then I'd suspect the ECU itself.
When you say that the car wouldn't turn, do you mean that it will not turn over at all? -Or will it turn over but just not fire (spark ignition)?
How did your caps in your ECU look like? -Were they recently replaced? If you want, I'll stop by your Jiffy Lube some time this weekend (if you are working then) and take a look...
If need be, I can always use my test ECU to make sure that the problem is not ECU related... It's got new caps & already socketed.
JLMK
Offline
Old 04-04-2008, 09:37 PM   #6 (permalink)
Proven Member
chavez408's Avatar
Region: NorCal
Yeah I know it would cost a problem but the 660's are at my ex's house. But oh well thanks guys ill get them in tommorow
Offline
Old 04-05-2008, 11:44 AM   #7 (permalink)
Proven Member
chavez408's Avatar
Region: NorCal
Alright guys, problem solve. I toss in the larger injectors and she fired away.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removed DSMLink from 97 GSX replaced ECU with 2GA Gst ecu... Cause this hesitation? EclipseTrbo420A Tuning & Engine Management 13 11-29-2006 08:04 PM
Need help with PK/ Mechanical Knock issues w/ DSMLink. project_tsi Tuning & Engine Management 11 05-21-2006 11:42 AM
ECU and DSMLink MadTripper Newbie Forum 3 05-19-2006 04:32 PM
ECU+ vs DSMLink Splitpi Newbie Forum 54 04-13-2006 08:31 AM
DSMlink vs. ECU+ JeanDSM Newbie Forum 6 10-28-2005 03:08 PM
Page generated in 0.14826012 seconds (76.46% PHP - 23.54% MySQL) with 10 queries
