Xaeryan
- Nov 18, 2002
OK, I'm ADDING a fuel pump to my car for a water injection system I am making. The relay described in vfaq.com splices into the factory fuel pump wiring in order to power the relay's coil (terminal 85). What would be a good power source for me to do this, considering I don't want to splice into the current harness.
As an alternative, I was thinking of not attaching the relay coil wires (terminals 85 & 86) and just making the output wire 87a (the output terminal used when the coil is not active) but I think that would mean the fuel pump would be on even when the car isn't.
So what's a good source that's only on when the car is on (run or started, whichever).
If possible, a generic (non-Eclipse specific) source would be good, cause I'd like to do this on my other car, eventually, too.
o
