1990 GSX - EGT Gauge going Full RICH!
Status
Not open for further replies.
GSXlaunch
392
Sep 3, 2003
The past couple of times I have driving the car the egt gauge has been stuck on the last green light meaning it is full rich. This only occurs once the car has been driven for a while, otherwise it works fine. I am trying to figure out what is causing this. Perhaps it is a simple connection problem. I did notice that my logger shows O2 FT at 100% as soon I start getting on it. If I am just cruising, FT% fluctuates normally but as soon as I start to give it more gas it goes right to 100% and stays stuck there. My fuel trims are as follows:
low = 81.2%
med = 98.4%
high = 85.1%
I am running boost at about 10-12 psi right now but want to up that to 25+ pretty soon. I've got the stg 3 chip with injector comp for 780cc's. I've got my GM Maft trans set to read 450cc injectors. My AFC is set to the following:
800rpm = -8
2400rpm = -10
4000rpm = -12
5600rpm = -12
7400rpm = -4
I am not seeing any knock at all and the car actually is driving pretty good even tho it is running a little rich.
How would an EGT gauge tell you if you are rich or not??
superdaddy said:
doesn't high egt gauge readings mean its running lean..... :confused:
It Can, or it cant. He did mention that his last green light was on, meaning that its a a/f guage. EGT gauges have needles and use the full sweep guage.
low = 81.2%
med = 98.4%
high = 85.1%
800rpm = -8
2400rpm = -10
4000rpm = -12
5600rpm = -12
7400rpm = -4
Those fuel trims are OK, however I would actually richen up the low and high a tad. 80-100% is where you want to be, but your cutting it a little close w/ the 81.2% and 85.1%. Also lots of people will tell you that a A/F guage is mearly nothing more than a cool little light show. A Proper working true EGT guage will tell you how your car is running, rich or lean, at any given time. Whereas a A/F guage only will tell you mixture that your computer "thinks" you are getting. My A'F guage reads rich all the time, but I know it runs good, according to my logger, and EGT guage.
Hope this helps.
Hope this helps.
So, you're telling me timing has NOTHING to do with what the EGT gauge reads?? :rolleyes:
egts dont tell you anything except whether or not your car is pulling timing and that doesnt necessarily equate to running lean.
EGT=Exhaust Gas Temperature. A thermometer.
A/F Gauge=pointless blinky lights, unless you sink half-a-thousand into a wideband sensor and reader.
Come on back when you figure out what you're talking about.
Status
