Ignition coils?
niap101
Mar 13, 2002
Austin, Texas
It appears that my rough running engine is being caused by a weak ignition coil. The resistence across the primary coils are each about twice factory specs. I just checked with the auto parts store; $260 for a pair of coils. Are there any upgraded coils I should consider since I've got to spend so much anyway?
Thanks
Niap101
There are no direct replacement high performance coils.
The MSD Blaster Motorcycle coils work well, but they require custom mounting.
Hal
