TURBOSPYDER
- 143
- Feb 21, 2002
Daly City,
I have my new pocketlogger and I did one third gear run starting around 3500 RpM . Heres roughly what I had.
From 3500-4000RPM, Timing went from 20deg to 8degrees. After 4000 RPM Timing was slowly rising and I ended up with 15 degrees of timing at 6700 RPM. This was done at WOT
Am I too rich or too lean? I only hit EGTS of 820C.
I have 720cc injectors with boost set at 1.45 bar with EGT's hitting 875c. I did a couple of test runs yesterday and Richened the AFC settings 3% accross from what I had. I noticed the timing advance alot, and I still manage to hit EGTs of 870-875c. I might richen more to about 2% just to see how it goes. Let me know what you guys think.
