custom240sx
- 91
- Sep 9, 2002
Okay i have bought a walbro 255lph fuel pump. I was under the impression you could run this and be happy untill you get an afc and injectors. No i come to find out i need a 1G fuel rail and an afpr. B/C the pump will over run my stock unit. So i have been looking around on the trader for some rails i have found some. One is just the rail nothing special. That other one i found says it has a -10 fitting welded on one end so you can bolt on the FPR. Do i need that or do i just need a fuel rail
Also, do i need new lines, and i hope to god i dont need new injectors. Damn why could this not be easy, like just buy a pump and be happy. Then i will need a fuel pressure gauge to mess with the afpr right.
