dustkrock
- 43
- Mar 30, 2009
mcdonald,
Pennsylvania
what ever anyone does do not go to mario i had a horrible experience with him i had purchased a 2.3 stroker 6 bolt. i got it off him right away i heard a ticking noise coming from it he assumed it was just a bad set of lifters so of course i bought them I had to pay wasnt it. then he pulled the pan a rod bearing was bad he only replaced them once again i had to purchase them then once again i took it back to him to get evertything figured out he took it apart again and took to machine shop i had to pay for the crank to get redone on it plus purchase bearings again for it he was claiming that the fidanza clutch had caused the problem with the thrust bearings which i had taken to several mechanics and they said it was starvation of oil and that he didnt plastigauge any of the tolerences. after he put it back together again no noises but had a stripped exhaust manifold stud main water line wasnt bolted down and a coolant line held on by a zip tie so just a warning to anyone who lives near washington pa or thinking of using this guy i advise you not to unless u want to spend 6k like i have to get a motor together and 5 months to spare
the waste needs cooling too? Crap time for some more water lines
