Login
Go Back   DSMtuners > DSM Forums > Regional DSM Events > Tri State Region DSM
Welcome to DSMtuners
Tri State Region DSM: New Jersey, New York, Pennsylvania
Reply
LinkBack   Thread Tools
Old 11-27-2009, 09:58 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
alansupra94's Avatar
Tech Posts: 216
Classifieds Rating: 0
Reputation: alansupra94 is an unknown
Send a message via AIM to alansupra94
In need of some help with my 1991 Eagle Talon....willing to pay!
Well, after I started this semster at school, I realize, I do not have the time to fix my car. It is a 1991 Eagle Talon w/ 6 Bolt AWD.
Right now, I am unsure of what is wrong with it and could use some help from people that know the car thoroughly. I would be willing to pay for your time and help.
The car and me are both living in Wayne, NJ and have ample room to work in (I have a cul de sac).
If you need some extra cash, send me a pm or gimme a call at 973-900-0981.
Thanks!
Alan
____________________________
1992 Mitsubishi Galant VR4
mark post as helpful recommend reputation points    Reply With Quote
Old 11-27-2009, 09:39 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Side_Show's Avatar
Tech Posts: 150
Photos: 3
Reputation: Side_Show is an unknown
What wrong with your car, like atleast some symptoms? and what the hell is "cul de sac"?
90LaserRS Turbo-DD
93GSX-10s Project
View photos of this member's car
Old 11-28-2009, 03:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Tech Posts: 216
Quote:
Well the car turns over and there is spark but still no go. There was a problem with the fuel line that it rusted out but I replaced it along with the fuel pump (had a spare walbro from my supra lying around).
I can hear the pump turn on....there is pressure in the line but still nothing.
I basically need someone that knows 6 bolts in and out to come look at the motor. Might be fuel injectors....might be timing....i am not sure but I know I don't have to the time to sit around trying to figure this out.
I would be more than willing to lend a hand wrenching on things but its just that I don't know DSMs that well to be good on my own.
EDIT: This is a cul de sac
Last edited by alansupra94; 11-28-2009 at 03:52 PM. Reason: Auto-merged with previous post to prevent "bumping"
Old 11-28-2009, 04:46 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Supporting Member
LTUDSM's Avatar
Tech Posts: 1,293
Photos: 9
Classifieds Rating: 3
Reputation: LTUDSM is more helpful than not
Send a message via MSN to LTUDSM Send a message via Yahoo to LTUDSM
cul de sac is "Dead end" So the guy probablly ment ,that he lives in the street,where is no transpassing.otherwise The end of the street,there is a circle just to turn around Thats what i think,i might be wrong :P
Old 11-28-2009, 06:21 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 216
Quote:
yup 100% correct....I might have a picture of my cul de sac somewhere....ill dig it up
Old 11-28-2009, 06:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
FluxCapacitor's Avatar
Car: 1992 Nissan 240sx
Tech Posts: 5
Reputation: FluxCapacitor is an unknown
A culdesac is also known as a cove around these parts. The end of the street looks exactly like the picture Alan posted. Cul de sac generally translates into dead end road. I believe it's french.
Old 12-02-2009, 04:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Tech Posts: 216
UPDATE
The shop I took the car too told me he thinks the timing belt jumped a notch. He is going to check to see if the valve is bent tomorrow.
Does anyone have the tools and knowledge to reset the timing on the motor and replace a valve?
Thanks
Alan
Old 12-03-2009, 09:33 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
DSM Wiseman
blcknspo0ln's Avatar
Tech Posts: 5,437
Photos: 68
Classifieds Rating: 5
He'll most likely do a compression test and/or leak down test. If you have a valve that is toast, you will at a minimum have to remove the head and get it removed&replaced (the valve and any other necessary work).
~Tom
Old 12-04-2009, 09:45 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
toyotaturbo's Avatar
Tech Posts: 165
Photos: 5
Classifieds Rating: 4
Reputation: toyotaturbo is more helpful than not
What kind of fuel pressure regulator is on your DSM? If it's stock, then it could be getting overrun by the bigger fuel pump, thus flooding it out.
Shawn Brown
Boost Boyz Racing
4g63 RWD Corolla
Visit toyotaturbo's homepage!  View photos of this member's car
Old 12-05-2009, 06:42 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Tech Posts: 216
Quote:
Interesting because I do have a stock fuel pressure regulator....should I toss a stock pump in there to see if that fixes the problem?
I will have to see if I have one.
Old 01-16-2010, 09:05 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
slvrbllt's Avatar
Tech Posts: 94
Reputation: slvrbllt is an unknown
I am also searching for a dsm guy. My dsm just blew the head gasket but i want someone to come check it out throughly to fix any other problems it might have. Send me a pm and Ill get back to you asap. got a 92 laser that I want to keep on the road!!!!!!!!!
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 747
278 members and 469 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
