You will pin those cams, get a set of cams that are stroker specific, The FP3s would be perfect>>>>
http://linux.forcedperformance.net/m...egory_Code=DSM. Seriously dont even through the 16G on there, just sell it if you already have it, and get something biger, the lowest I would go is 20G, 50 trim, 60-1. Those witha set of FP 3 cams will be fully spooled by 4k. People use GT30s, and 35s, on the strokers and they spool nicely as well. Not sure if the trans will bolt up to it since your using a 4g64 block, and same goes for the 2g head. I would imagine that they would bolt right up, because no one would by that kit if they had to get a different head and trans just to get.1l more of displacement, when they could use a 4g64 crank, 5.900" rods, and 2.3L stroker pistons.
Dustin
