boosting_laser
- 268
- 5
- Jul 21, 2004
Whittier,
California
This time its for real. Im satisfied with what Ive accomplished with this car & dont have the desire to take it any further. The car threw a rod bearing on #1 & that sealed the deal. Like all DSMs shell get parted out if she doesnt sell. Tags are current & title on hand. This is the perfect platform for a fast drag car. I'll break it down into two options. Either buy it all or take the rolling chassis with extras to sweaten the deal.
-The whole enchilada. '91 Eclipse AWD= $3,800
HUGE list of parts!! Does not include shift light, oil pressure gauge, N20, & wideband.
-Rolling Chassis w/ included extras listed below:
*$1,200 your wheels
*$1,400 w/ RX-7 & Yokohama
*$1,500 w/ Drag DR17/Hoosiers
*$1,600 w/ both sets
*Complete Automatic Drivetrain*
Trans w/ shift kit & end clutch kit, B&M trans cooler, in-line filter, 4K re-stall, 4 bolt rear, kiggly mod w/ B&M slap shifter, Autometer trans temp gauge, All axles, t-case, driveshaft
*Fuel System*
Walbro 255hp in-tank & inline pumps, Golan filter, -8AN feed line/fittings from pump to rail
*Suspension/Steering/Brakes*
MOMO wheel, manual steering rack, KYB AGX w/ Ground Control sleeves & no name springs, extended wheel studs, Metal Masters pads, SS brake lines, all motor mounts, poly bushings installed in front end (rear end poly bushings not installed, but included)
*Misc/Exhaust*
3 Downpipe w/ cut-out & stock cat-back, JM Fab bumper brace, Autometer fuel pressure gauge, Stage 23 gutted interior, EPROM ECU, Complete wire harness
PM, call or text @ 562-569-2632
Prices are frim & more then fair.
I can tow to you, but you cover gas & trailer expense.
**Will except the following**
Money, AMC 360/390/401, related engine parts, Torqueflite 727 trans, Dinero, small car AMC disc brakes & V8 crossmember, dead presidents
*$1,200 your wheels
*Fuel System*
*Misc/Exhaust*
