Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > SoCal DSM Forum
SoCal DSM Forum SoCal, Vegas, and surrounding areas.
SoCal Region Homepage
Reply
LinkBack Thread Tools
Old 05-22-2008, 12:51 PM   #1 (permalink)
Proven Member
Region: SoCal
Classifieds Rating: (0)
Reputation: Phalanx99 isn't as helpful as most
FS: 97 Spyder 2.4L turbo
1997 Mitsubishi Eclipse Spyder GS (2.4L turboed).
Mileage: 118k
Lots of mods:
97 Eclipse Spyder GS turbo list:
Tripple gauge pod + Oil Pressure, Oil Temp, Boost : $130
Gauge cluster : $26
Ebay HKS Blow Off Valve : $47
Evo VIII fuel pump : $55
550cc Injectors : $200
Tabular manifold with 38mm External Wastegate : $195
28X12X3 FMIC : $106
Intercooler pipes: $54
Injector resistor pack : $26
EGT gauge + Digital tachometer with shift light : $120
EPROM ECU : $230
Reducers and Couplers: $50
DSMlink + Socketted : $600
Turbo oil lines: $100
2g Knock Sensor: $40
1g Throttle Body: $50
2g Throttle Body Elbow: $26
3" Aluminum pipe with HKS flange: $20
- Infinity speakers all around. 2 way speakers front and 3 way speakers back: $200
- Megan racing front upper strut bar: $24
- JVC CD/MP3 player: $120
- RED interior lights: $40
- All stylist decals: $100
- Custom interior paint: $20
- Custom Red/Black leather seats: $100
- 2.5" Greddy cat back exhaust: $250
- Interior trims, hand brake cover, ball shape shift knob: $40
- Chrome dual projector headlights: $110
- Short shifter: $33
- BLUE silicon vacuum hose: $10
* Engine upgrade at 115k miles:
- 4g64 SOHC BLUE plug wires and Irridium spark plugs: $95
- Wiseco pistons 9.1:1 $460
- Eagle H-beam rods: $320
- ACT 2100lbs clutch with 6 puck disc: $300
- New 4g64 oil pump: $95
- New 4g64 water pump: $40
- New alternator: $150
- ACL race bearings: $90
- Balancer shaft eliminating kit: $25
- Multi layer metal head gasket and engine gaskets: $65
- FIAV and EGR valve block off plates: $20
- T3/T4 57trim turbo
- Custom made urethane motor mounts from stock motor mounts: $20
- 3" GM MAFS with 2g MAFT : $250
- New belts: timing belt, alternator belt, AC belt.
- New AC seals + refrigerant: $160
*** The car is not running now. It NEEDS a new motor. ***
Pictures: 4g64.com Gallery :: Phalanx's Spyder
Pick up only !
Asking price: $3000
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 05-22-2008, 02:04 PM   #2 (permalink)
Proven Member
Project2G's Avatar
Region: SoCal
Classifieds Rating: (58)
Reputation: Project2G is more helpful than not
Sorry man this is not the classified section. Post that in the socal classified section.
____________________________
-Steve-
97 GST TD06 20G
Offline
Old 05-25-2008, 05:35 PM   #3 (permalink)
Proven Member
Region: SoCal
Isn't this SoCal DSM forum ?
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 99 Spyder GS 2.4L Turbo vanilla gorilla Photoshop/Photography Forum 21 04-30-2008 12:23 PM
Will a 3G Spyder Intake Work With a 2G Spyder? (2.4L) Eclipse98Spyder Bolt-on Tech 2 10-26-2006 05:34 PM
Page generated in 0.12616706 seconds (74.39% PHP - 25.61% MySQL) with 10 queries
