90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
I installed a Greddy Emanage with the support tool, and ignition harness this past weekend. I bought it from http://www.mohdparts.com/emanage/index.html really good price and super fast shipping. I followed an install write up on the emanage yahoo group, http://autos.groups.yahoo.com/group/emanage/ . Very easy to install and setup.
My setup prior to install:
K&N
3" GM MAF and MAFT
ported 16g@20psi
EVO III exhaust manifold
2.5/3" downpipe
3" cat
3" catback
2.5" upper intercooler pipe
rewired 255 fuel pump
B&M fpr@50psi
PTE 680cc injectors
BPR7ES plugs
With this setup I had to retard the base timing to prevent knock under boost. This caused some drivability and idle problems. I had to run pig rich just to get the car to idle. If I ran stock base timing the car idle and cruised great but knocked severly under boost. I needed to retard timing while only under boost. The emanage has aloud me to do this.
With the support tool you get access a basic fuel injector correction, corrections for different maf sensor's, although for us this doesn't give a whole lot of options becuase you have to stick with the same type of sensor, I'm still using my MAFT for the GM MAF sensor. You also get access to an anti stall map for all you vent to atmospher guys, I have no desire to vent so I didn't play with this. You also get a 16X16 air flow map, throttle postion Vs. RPM. And also a map trace feature, real time display, and datalogging.
With the ignition harness you get a 16X16 map, airflow Vs. RPM.
The install was very easy, the basic install is just like an SAFC, the ignition harness is four additional wires.
Setup was also extreamly easy, setup the injector correction, and throttle position and the car is ready to run. I've got it running pretty good, still trying to get every thing perfect. My low trim is at 118, mid 101, and high 103. Idle and driveability are exceptional. I'm currently playing around with the timing, I'm getting real close to where I need to be.
I highly recommend this setup, especially if your having timing issues do to large injectors. There are some other options I didn't get, check out the links above to find out more about those.
K&N
3" GM MAF and MAFT
ported 16g@20psi
2.5/3" downpipe
3" cat
3" catback
B&M fpr@50psi
PTE 680cc injectors
BPR7ES plugs
