JDM Vacuum LIne Diagram Complete.
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
Hey, i remember reading posts where people just would love to see how the cyclone and everything is supposed tobe hooked up, and I WOULD ALSO loved to have this info when doing my swap, so i found it, here it is,
if you need it good, if you know someone who does, show em,
later
Thanks, Pax, it's interesting. Apparently that "mushroom" on the left is just a filter? I think the kanji there says, "See if the stupid round-eyes can figure out the picture's upside-down."
I cleaned it a bit with PS, should hold until some CAD guy gets to it.
cool dude, check this one
Where's Arctic? Doesn't he read this stuff?
Is that can at the bottom of the first picture the actuator for the Cyclone? I see it's controlled by a solenoid valve on the right, and again I think that "mushroom" is a filter.
Are you running yet? Does the Cyclone seem to work?
I can translate! Well, I can translate most of it....
Top says "Vacuum Hose Layout (Bakyuumu Hoosu)" (or pretty much that's how it says I'm guessing.. I'm not well versed in Kanji, but Katakana is simple).
The arrow is pointing to the front of the car, so flip it around to see it more clearly. (Kuruma Mae) as far as layout.
Blah, lemme translate this for everyone with photoshop... It'll be much easier to show.
Some of the stuff I couldn't read due to the fact that the text got really distorted from the picture (a Higher rez version would've been easier to work with), but here it is to the best of my abilites. The parts with ?? are approximations.
Someone else who's more knowledgeable probably could do it better, but... you get what you pay for, right?
And that second one is a big blur, although all it really looks like is mainly a boring spec sheet about what the engine is in displacement, etc etc.
Edit: Everything is translated/documented, but the solinoids aren't marked any different or more specific than just as "Solinoid Barb"..
where you have airpressure valve, that is the breather on the valve cover.
also, its all hooked up and running from the ecu, i dunno if it works thouhg, because i dont know what its supposed to do, LOL
Changed it. Just trying to translate as they have it in japanese.
There's definately a solinoid there that controls the cyclone unit...
oh yea, definatley, the bottom on, or the one that has the line running to the vaccuum tank is the cyclone controler solenoid. without a doubt.
it runs off the EGR plug on the american wire harness, if you have the ### ecu.
latest news, engine shop cant fix my engine, they dont now how to tune it.
ahahahha
Translate this too! It came off the dash of pax's swap clip. I'm gussing it's asian AAA:D
DSMTuners, if you could hold of on deleting this thread i am still refuring to the pictures and link's i will respond when i am done with it thank you very much
Donovan
