mattn
- 128
- 0
- Jul 24, 2002
I recently had to replace my motor due to throwing a rod.. Now that I have the new engine and tranny in, the clutch does not completely engage when I let off the pedal. I've checked all the clutch lines and the master and slave cylinders appear to be working correctly.. no sign of leaks at all in any of the clutch lines. I've bled the clutch about 3 times, thinking that maybe there was air in the line and that would keep it from engaging fully. Apparently that was not the problem...
Here's basically the summary of symptoms:
- Rev engine to about 3-4k rpms in 1st gear and car does not want to move... could barely get the clutch to engage enough to move up a slight hill.
- Speedometer moves when trying to move... (eg. shows going 20mph when im doing maybe 2 trying to get the car to accelerate)
- Shifts into gear perfectly. As it did before the engine swap.
- We DID NOT use a clutch alignment tool when putting the assembly back together. We used a socket of similar size, but made sure that we got it damn near perfect..
- Took apart and lubed up the entire TO bearing.
- When the clutch started acting funny, I heard a loud "clunk " from the engine bay..
Now I'm thinking this is all because I didn't properly align the clutch, but I'd like to have some more input before I go dropping the tranny... A friend of mine also said he had a similar problem, and just had to have the clutch pedal adjusted.. the manual says clutch height while engaged should be 7.1" and mine is about 5.5"..
any help on this would be greatly appreciated.. i miss my car
