2G Will 1g awd tranny fit in 2g awd?
dsmizike
Jul 30, 2003
Festus, Missouri
I am in the middle of a project with a 95 talon tsi AWD and i need a transmssion. I was just wondering if a 1st gen awd tranny will work for a 2g awd. if it makes any difference i am running a 91 gsx motor. Any help will be greatly appreciated. Thanks
dsmike:talon:
You can make it work, and i have seen it done, but it is not easy. THe mounts are different, so it will take some custom fabrication work to make it fit. Likewise, the output shafts are different. The 91 tranny will be a 23 spline, and the transfer case in the car will be a 24 spline. You will have to switch the output shafts in the tranny, or trade transfer cases. However, i am not sure that the 1G transfer case will fit in the 2G car....i have never had a reason to try.
