Intake manifolds testing - April 3
DCJ98GST
435
Aug 16, 2002
Philly, Pennsylvania
Looks like RMDSM.org is doing testing for Intake manifolds:
http://206.124.12.138/manifolds/index.html
RMDSM.ORG presents the 2004 Intake Manifold Shootout on April 3rd, 2004
FRH
BJ'S
Magnus Motorsports
Extreme Motorsports
Venom
STR
Mitsubishi 2g intake, extrude hone
Mitsubishi 1g intake, extrude hone
Stock 2g intake
Stock 1g intake
The test
Mount each intake on the same test vehicle
Run the test vehicle on an all wheel drive dynamometer (Dynojet 248/224)
Record the following
RPM
Air flow (in grams per rev)
Air fuel ratio
Torque (uncorrected)
Horse power (uncorrected)
Time index
The test vehicle (courtesy of Dave Landry)
1990 Eagle Talon Tsi AWD
2.0L 4g63 (8:1) motor using 30 psi of boost
Stock head casting
HKS 272 intake/exhaust cams
Stock throttle body
2.5" intercooler piping
3.5" GM MAF (blow thru)
MAFT (zeroed out)
Buschur Racing front mount intercooler
Forced Performance 3065 turbocharger
No intake on the turbo
No exhaust beyond the 3" tubular o2 housing
DSMLink V2
The results (installed pic, video of pull, dyno charts, dsmlink dat and csv)
Should be interesting.
i lub hal.
Great job for going through all the trouble:thumb: I'd like to see the Buschur SMIM included in the testing though:confused:
Anyone taking bets on which will give the most hp?
I am going w/ BJ's or FRH
Just a note about this test.
We are not running around asking for intakes to test.
The intakes being tested are those that we have been asked to test.
Manifolds have been submitted by individual owners as well as vendors.
If Buschur Racing wishes to submit a manifold or if the owner of a Bushur Racing manifold wishes to submit his/her manifold for testing, we will gladly add it to the list.
The fact that a specific manifold does not appear on the list should not be taken as a negative.
In addition, there is more to manifold performance than how much torque/hp a manifold makes.
Where in the powerband does it start to "make" power, and how long does the power band last.
Different manifolds will have different curves, but at the same time those different curves may suit individual setups better.
Daily drivers, auto-x, and drag racers will all have different power band needs.
Matching the manifold to the performance goals of the car will ensure you get the best performance for your investment.
Finally, quite a few people are involved in this test. Everyone listed on the webpage deserves a thank you from the DSM community for helping to make this test happen.
Hal
When is this testing going to be completed? This should be very interesting.
Many people will awaiting the results from this test. It will help alot of people be able to choose an IM for there needs.
wow, this is gonna be great!!:thumb: thanks to all the people named on the site.
I think the two main competitors are the SMIM and the FRH!! which will make more power without losing bottom end?
good thing I didnt buy one yet.
and dont forget to do a pressure test after each manifold install ;)
Originally posted by DCJ98GST
FRH
BJ'S
Magnus Motorsports
Extreme Motorsports
Venom
STR
Stock 2g intake
Stock 1g intake
I don't see it on this one.
What are your precautions for making sure all the dyno runs are under the same conditions? For example, your first manfold might be on a crisp morning run at 9 am, but the last one may end up being done at 2 pm when the sun is blazing at full strength.
Is the car going to be cooled or warmed up before each dyno run?
Are the runs going to be open hooded? Fanned?
How many runs each? Are you going to try to finish all the manifolds in one day?
What you're doing is really awesome, and definately not an easy task. I just wanted to ask because i'm curious and would like to see the data accurately displayed (even if it means saying that manifold #1 was run at 60 deg but Manifold #5 was run at 80 deg) so that we can make accurate comparisons.
I'm sure you know what you're doin though and i'm probably just blabbering off on things you already know. :thumb:
