fog light bolts
tbTalonES94
333
Jun 23, 2002
Cedar Rapids, Iowa
I was wonderin if anyone has a suggestion about removing rusted bolts on the fog lights. I have tried to spray wit WD and use a torch to heat and make bots bigger to stretch out and still broke screwdriver bits. Does anyone have any ideas???
Are the actual fog lights out? The fog lights are held in by two screws (I had to drill them out with a drill) and then the fog light bracket was held in by three bolts... Are you planning on putting new aftermarket fog lights in?
Well then if you break the heads off the bolts then the bracket that holds the fog lights in will come out. Get some better sockets so you can get them out...
